Siemens Washer dryer D12.52
  • #68831
    mike412
    Hi folks.
    I need the E nr for this machine in order to identify and order some door parts from BSH. Unfortunately the label inside the door has been rubbed off, also the label normally to be found on the back is missing.
    Anybody got one of these machines or in any other way can help with this enquiry,
    Many Thanks,
    Mike
    Happy Easter to All.
    #372912
    Re: Siemens Washer dryer D12.52
    mike412 wrote:Anybody got one of these machines or in any other way can help with this enquiry,
    Up-load some photos of the machine so we might be able to ID it? 💡
    #372913
    mike412
    Thanks Martin.
    I might in fact have solved this one. I went into the Connections Mediator which comes up with a list of most of the BSH e numbers. There is just about enough of the enumber on the inner door so it could be …….?20/GB/01. If I assume that ?= 5, the only washer dryer with similar numbering is WD12D520GB/01. Looking at the BSH website it looks right and as the parts I need are not too expensive I think i will take a punt.
    Thanks for your interest and enjoy whats left of the Bank Holiday. (peeing with rain here).
    Mike.
