Siemens washer/dryer door lock intermittent
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Siemens washer/dryer door lock intermittent
  • #102076
    hughwatkins
    Hi, I’ve got a 8yr old Siemens washer/dryer that is in good working order. Sometimes at the start of the cycle the machine complains the door is open. You just give the door a little extra push and the lock clicks shut and then the cycle goes fine. It’s only ever at the start of the cycle.
    I’m going to replace the door seal as it is mouldy and leaking. Is there anything I could do at the same time to fix the door issue?
    Thanks.
    #487462
    cant hurt to change the door interlock as well
    What is the Enr and Fd number ?
    hughwatkins
    E-Nr: WK14D541GB/07
    FD: 9612
    Thanks Dave
    #487464
    well the rubber is over £100 on siemans site and the lock is in the £75
    this unit is made by Smeg for Siemans
    so the lock should be
    https://shop.ukwhitegoods.co.uk/8144…hine-door-lock
    door rubber
    https://shop.ukwhitegoods.co.uk/7541…ryer-door-seal
    cant be 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} but fairly certain these are correct. you could ask shop to confirm
    hughwatkins
    perfect thank you.
