Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Siemens washer dryer E12 error code
- This topic has 5 replies, 3 voices, and was last updated 4 years ago by
hughwatkins.
April 3, 2022 at 8:11 am #100704
hughwatkins
ParticipantHi,
Our Siemens washer dryer is showing an E12 and 3 minutes into every cycle.I’ve tried checking the inlet filter and cleaning as best I can the outlet hose and front access filter.
I’ve taken the top off and water sounds like it’s flowing well in the machine. But I’m not 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure.
On a Empty+Spin cycle it appears to be draining ok. Although the outlet pipe had debris in it.
Model: WK14D541EU with aqua stop
5yrs old, medium usage.Anything else I can look at?
Thanks alot.
HughApril 3, 2022 at 9:56 am #481820electrofix
Moderatorsound like it may not be detecting water entering machine properly. check pressure switch and tubes to it for blockages
April 3, 2022 at 11:11 am #481821hughwatkins
ParticipantThanks a lot Dave
is the pressure switch the black flexible tube in this photo?
the clear tube is rigid.April 3, 2022 at 11:13 am #481822hughwatkins
ParticipantSorry didn’t mean to post above.
is the pressure switch usually accessed from the bottom?
thanksApril 3, 2022 at 11:44 am #481823electrofix
Moderatorthe pressure switch is normally at the top inside. its fed by a thin tube from a bell that traps air at the bottom. check hose for blockages and damage
do not blow directly in the switchremove and replace connection in case of bad connection
November 15, 2022 at 10:30 pm #481824Frsin
Participanthello
i have a washer dryer with e12 showing updid you have to change a component and which one please ?
I have read online is that it is the 3 head inlet or the aqua stop that can go bad. Do you have a more precise idea from the repairs you had to make
thanks v much
hughwatkins wrote:Hi,
Thanks alot.
Hugh -
