Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Siemens washer/dryer problem
- This topic has 7 replies, 2 voices, and was last updated 10 years, 3 months ago by
Felix64.
December 28, 2015 at 8:53 pm #87147
Felix64
ParticipantHi, I’ve got a mysterious problem with our Siemens WXD1260 washer/dryer. Please bear with me because I’m a bit of a DIY numpty. We had it installed 7 years ago in our new fitted kitchen and it’s been pretty reliable until a few weeks ago, at which point it stopped drying, leaving the clothes wetter than at the start of a dry cycle, or stopping during the cycle with a F04 fault (supposedly signifying a pump or outlet hose blockage). I called out a domestic appliance engineer who confidently told me there was no problem with the machine, and the problem lay in the way it was installed; the machine’s outlet hose is connected to a 4ft extension hose so it can reach the trap under the sink, and he told me that the extension hose was too long for it to drain properly.
Since then though, I’ve been investigating further. Maybe the guy was right, because I found that just draining through the machine’s hose into a bucket, it still dries ok; in fact having thoroughly cleaned out the extension hose, it also works draining through both hoses into a bucket. However, when I connect the extension hose back into the trap under the sink, it stops working again. There’s no blockage there, the sink drains perfectly. And, when a dry cycle fails, even with a F04 fault, if I immediately put it onto an “empty” cycle, it drains ok.
So, has anybody any bright ideas? Maybe the installation isn’t ideal however I never realised at the time and it worked fine for long enough. I also know that maybe I should be thankful for getting 7 years reliable service from a washer/dryer, given the bad press they get; however given the evidence in front of me I’m not convinced buying a new one will be the answer. Do I need a domestic appliance engineer, a plumber, a new machine, or all of them?
Any advice much appreciated!December 29, 2015 at 12:06 am #434075electrofix
ModeratorRe: Siemens washer/dryer problem
have a really good look at the extension. especially the joint. i have had buttons and 5p ‘s get up hose and block the joint sometimes ie act like a flap valve
December 29, 2015 at 6:46 am #434076Felix64
ParticipantRe: Siemens washer/dryer problem
I’d hoped this might be the cause too, the engineer that visited suggested it – indeed he found a button doing exactly that in the machine’s hose. However I removed the extension hose yesterday, peered down each end and gave it a thoroughly good clean with a bottle brush attached to the end of a drain cleaner. It’s as good as new now.
I was reading on this forum other people’s experiences of F04 faults on Bosch machines, though the symptoms were a bit different, and was wondering whether the pump could have gotten weaker over time. It seems to pump ok though I don’t know how strong it’s supposed to be. I’m struggling for an explanation when all the waste outlet seems to be clear.
December 29, 2015 at 8:18 am #434077electrofix
this type of pump wears and starts to drag. had a similar prob with a bosh auto not pumping all the water out. swopped pump and no probs after that
December 29, 2015 at 8:22 am #434078Felix64
electrofix wrote:this type of pump wears and starts to drag. had a similar prob with a bosh auto not pumping all the water out. swopped pump and no probs after that
Thanks for your help – is replacing the pump a job for a reasonably skilled engineer or could anyone do it?
December 29, 2015 at 8:05 pm #434079electrofix
its not difficult. most of the time its 2 pipes and a plug. if there is no base on the machine you can access from underneath. lean the machine backwards at 45 degrees and see if you have access
DaveDecember 30, 2015 at 8:39 pm #434080Felix64
Thanks, I think I might give replacing it myself a go. Can you please tell me which part number I need for the WXD1260 assuming it would be best to get a genuine Siemens/Bosch spare rather than a generic one? Maybe I’m being blind but I couldn’t spot it in the shop link.
December 31, 2015 at 6:56 pm #434081electrofix
go here
http://www.siemens-home.co.uk/customer- … pare-parts
put your full Enr in and you get a full parts breakdown
