Siemens washer dryer – replacement motor
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Siemens washer dryer – replacement motor
  • #96365
    asdrewq
    Hi All,
    I have a Siemens washer dryer model number:wd14h320gb/02. Not sure how old it is but i’d say at least 4 years.
    I noticed a faint burning/electrical smell coming from it – having taken it apart there is smoke coming from the motor when under load, particularly on a 1400 spin with a full load. The motor feels really hot.
    I stripped the motor down but couldn’t see anything obvious wrong with it – brushes had plenty of life & the windings measured 1.9ohms or so (possibly low – not sure)
    I don’t really have any experience repairing appliances – Is it likely it is just worn out & needs replacing? It still seems to work fine, it just smokes. and its not a lot of smoke, but enough to give a really bad smell in the room.
    The markings on the motor are as follows:
    Model no: 129.60260 J1 (embossed in aluminium tab at top)
    Additional number: 9000804594 (in black text on front)
    From my limited research it is shared with the Bosch WVH28420GB, and probably others.
    Anyone have any ideas where I could source a replacement one from – are there appliance reclamation places out there?
    #463145
    well looked up motor for this machine
    part no 145495 Siemens retail price £213.50
    asdrewq
    Thanks Dave. Is that the Siemens part number? Any idea if its shared with any other model or where I might find a good 2nd hand one? It’s quite a lot to spend on a not-new machine.
    #463147
    that’s the Siemens part no and Ebay is the only other source of parts I know
    yes parts are used by Bosch Siemans and gaggenau but as far as I know part no are the same
    you can check parts here https://www.siemens-home.bsh-group.com/uk/customer-service/support/search-parts
