siemens washer dryer topline
Home Forums Public Support Forums Help And Support Washing Machine Help Forum siemens washer dryer topline
  • #55363
    oliverstorrie
    I have an integrated siemens washer dryer top line which is about 5 years old. I have never had any problems with it untill now.
    When i start a cycle (wash,dry,spin) the programme starts and then shuts down after about 2 minutes.
    If it is a wash cycle the machine will fill with water but fail to spin.
    Is there anyway i can find out the source of the problem?
    #323399
    don
    Re: siemens washer dryer topline
    You will need to post up the ENR number along with the FD number which can be found on the inside of the door frame.
    Don
    #323400
    oliverstorrie
    Here you go Don
    Hope this helps
    ENR- WK61420GB/13
    FD – 8204400083
    #323401
    don
    Hi Oliver
    Thanks fo the PM today.
    This thread may have been missed by one of the Siemens experts. Bringing it back to the top with a “bump” to see if anyone can help Oliver in any way.
    Don
    #323402
    chalky
    Hi oliverstorrie
    when you say it fails to spin do you mean the drum does not turn at all?
    #323403
    oliverstorrie
    Hi Chalky,
    Each programme starts wether it is a spin, dry or wash but cuts out after 2 minutes. On a wash it will fill with water but fail to spin.
    Hope this helps
    #323404
    bosch-engineer
    Hi, when the machine has stopped filling, listen carefully. Do you hear a relay clicking & no drum action? If you hear the relay operating but no motor action, then more than likely the motor brushes have worn. When the machine cuts out, do you get a series of flashing status LED’s. If so, which LED’s are flashing. This is a fault code & will point you in the right direction to a correct diagnosis. On your model, the carbon brushes come fitted on the rear bearing shield of the motor. The siemens part number is 496876.
    #323405
    oliverstorrie
    Yeah the machine clicks but then the drum fails to spin. Is it a big job to replace the brushes?
    #323406
    bosch-engineer
    Not a big job. Motor off, replace rear bearing shield (complete with brushes), click new brushes into place. Refit motor, job done!
    #323407
    carcon
    I HAVE EXACT SAME PROBLEM, SAME MODEL NUMBER, WHEN THE MACHINE STOPS YOU CANNOT ADVANCE IT THROUGH THE PROGRAM WITHOUT SWITCHING OFF/ON THEN MANUALLY FORWARDING THROUGH, IT WILL DRAIN AND IT WILL SPIN THOUGH. I CHANGED THE FRONT MOTOR CASE WITH THE BRUSHES IN, LAST NIGHT BUT STILL SAME PROBLEM.
    ANY MORE IDEAS OR TIME FOR NEW.
    THANKS
