Siemens washer dryer WD14H421GB/02
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Siemens washer dryer WD14H421GB/02
  • #100749
    SWERV
    I have been out to the above machine.
    The initial fault was the machine would beep and the tap light would flash after around 20 secs and then the machine would stop. The water would just trickle extremely slowly into the soap drawer, before it beeped and stopped.
    I replaced the valve unit and now the machine beeps and the tap light comes on, but it does carry on and goes through the cycle. The flow rate of the water coming in to the dispenser has improved, but it is still not flowing in very fast. The water pressure is fine and the dispenser is new, so I can’t see that being an issue.
    Has anyone come across this?, or can shed any light on what I am missing.
    Thankyou.
    Merv
    #482056
    was it a genuine valve you fitted ?
    SWERV
    Hi Dave,
    yes it was a genuine valve.
    Merv
    #482058
    was wondering about your light
    there is a reed sw flow meter on these valves was thinking the info may not be getting to the board. Either through bad connection or damaged wire
    SWERV
    Thanks.
    I’ll arrange to go back and have another look.
    Merv
