siemens washer pump WM16Y790GB/30 fault
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries siemens washer pump WM16Y790GB/30 fault
  • #97287
    mike100
    pump sticks intermittently and she has to drain down to get it to spin. Its Hanning type 00145777 quite expensive so got Maddox 51 BS 50. Trouble is drain hose that has rubber ring on it plugs into pump but when ran it leaked big time. Anyone had this trouble with pattern pump and if so have I got to get genuine.
    thanks
    Mike
    #466789
    not fitted one of these so i dont know
    have you looked at both pumps to see if you can swop over the motor unit if its the same fitting
