siemens washer – WIQ1430EU/01 – reposted
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries siemens washer – WIQ1430EU/01 – reposted
  • #13708
    razor
    got 1 of these machines in , the LCD displays – SIEMENS but thats all , doesnt go by this
    modules look ok . checked all wires
    anyone know which module is faulty here or is it the LCD display module at fault
    any help appreciated in this , cheers
    #156226
    Re: siemens washer – WIQ1430EU/01 – reposted
    Wow! You hit the jackpot there razor!!! 🙄
    This baby has 3 Modules and unless you have overlooked things like Door interlock, motor connections, heater etc etc you may have a problem?
    As it’s an IMPORT then the 2 year guarantee is likely void also (probably?) but may be worth checking though????
    You could always give Siemens ‘Tech Dept’ a bell on 0870 2426660 💡
    #156227
    BSH-MAN
    Martin wrote:Wow! You hit the jackpot there razor!!! 🙄
    I’m afraid so. 🙁
    We will, more often than not, repair on a chargable basis non u.k. appliances 🙂
    Not all EU tagged appliances are non u.k. 😉
    #156228
    razor
    thanks there lads , will ave a check at the other stuff , then probs phone tech
