Hi sometimes when my washer dryer has finished a cycle there is water left in the rubber seal of the door – it is normally when I wash at a low temperature although the machine is still set to spin at the highest setting. I have drained off the water at the bottom of the machine and cleaned the pumped of debris. However, if i put my finger at the beginning of the drain hose I can feel something. I am not sure if this is part of the hose or something has got stuck? I have tried to pull it out but it wont budge.
I put my washer machine on a cold wash and it is now coming up with code E01. I have checked for blockages and cannot find anything. Also I tried reset the machine by holding down the start button but nothing seems to work and it is continuously draining.
