Enr WM16S794 GB/01 The heater has failed in this machine due to the heater coming on with no water in the machine as the element was distorted and discoloured. The pressure system was clear. I did run a test and there is no supply to the element in spin mode. Anyone had this problem?
i have also got the exact same fault with this model and have changed the heater and pressure switch,checked for blockages but for some reason the heater comes on with no water or very little water in it,the machine will run o/k for 3-4 weeks.
