Siemens Washing Machine Extraklasse XLS 140 – Door open ?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Siemens Washing Machine Extraklasse XLS 140 – Door open ?
Viewing 4 posts - 16 through 19 (of 19 total)
  • #174687
    NickRCarter
    Hi, Thanks to this forum it appears the problem is the door lock. Having had you Guys id the part, can anyone give an indication of the degree of difficulty in fitting the part?
    Muchas gracias
    Nick
    #174688
    gegsy
    Re: Siemens Washing Machine Extraklasse XLS 140 – Door open
    Relatively easy. All done from front. Remove door seal retainer, peel door seal away from porthole, access from there. Power off of course :plug:
    NickRCarter
    Many many thanks for all your help. I was in the process of removing the offending part, when there it was….. one of the connectors had come adrift after 5 years of vibration!!! So all fixed and once again many thanks for your help.
    Best regards,
    Nick
    #174690
    gegsy
    You welcome, glad its sorted 🙂
