Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Siemens Washing Machine WXL 120GB/01 Stopped : No Lights
- This topic has 16 replies, 4 voices, and was last updated 14 years, 10 months ago by
JM_2.
June 10, 2011 at 9:19 am #63295
JM_2
ParticipantHi,
I’d appreciate some more help please.
I fitted a another working (used ) motor on to this machine about two weeks ago. Done around 8 washes.
Brushes looked OK before I fitted it.
The machine started Ok as usual last night . Water went in. Then apparently suddenly there was a noise : cracking sound.. Not sure what.
The machine has stopped completely with water inside.
There are no lights. Now the lights do not display on the fascia.
The fuse in the plug is OK. The mains power supply is working.
JM2
June 10, 2011 at 12:48 pm #353335Martin
ParticipantRe: Siemens Washing Machine WXL 120GB/01 Stopped : No Lights
JM_2 wrote:Then apparently suddenly there was a noise : cracking sound.. Not sure what
A few possibilities here, the motor and blown the PCB? The PCB has self-destructed? The door interlock has failed and taken the PCB with it? A mouse has got in a chewed through a cable? 😕
June 10, 2011 at 2:15 pm #353336kelland
some bosch machines (same as siemens) go into fault code when the brushes go and have to be cleared, on bosch machines if my memory serve me right is….turn dial to 6 ‘o’ clock posistion, press and keep holding spin speed button, turn one notch clockwise then 3 seconds later let go of spin speed button then turn to off posistion, but before all this check brushes
June 10, 2011 at 4:45 pm #353337JM_2
Martin wrote:
JM_2 wrote:
Then apparently suddenly there was a noise : cracking sound.. Not sure whatA few possibilities here, the motor and blown the PCB? The PCB has self-destructed? The door interlock has failed and taken the PCB with it? A mouse has got in a chewed through a cable? 😕
Thanks Martin.That doesn’t sound too good.
JM2
June 10, 2011 at 5:02 pm #353338JM_2
ParticipantSiemens Washing Machine WXL 120GB/01 Stopped : No Lights
kelland wrote:some bosch machines (same as siemens) go into fault code when the brushes go and have to be cleared, on bosch machines if my memory serve me right is….turn dial to 6 ‘o’ clock posistion, press and keep holding spin speed button, turn one notch clockwise then 3 seconds later let go of spin speed button then turn to off posistion, but before all this check brushes
Hi Kelland,Thanks for the reply.
I had checked the brushes. They seemed OK when I checked two weeks ago.
It has worked few times and now has suddenly gone. There is lot of water left inside.
Trying to work out your instructions. There are two dials
One for the programme on the left.
and
the right dial is for spin speed.
There are 5 buttons from left to right ;
1. Remaining Time / Time delay
2. Short Wash
3 Extra Rinsing
4. Less Ironing
5. Start
http://www.siemens-eshop.com/eshop/siem … XL120GB/01
So not sure which ones I turn and hold.
ThanksJM2
June 10, 2011 at 5:36 pm #353339Applianceman2010
Are you SURE one of the brushes havn’t snapped or jammed in the holders?
June 10, 2011 at 7:37 pm #353340JM_2
Correction. I am now being told that it went ‘ click ‘ and then stopped !
ThanksJM2
June 10, 2011 at 8:43 pm #353341Applianceman2010
Heater?
June 10, 2011 at 8:45 pm #353342JM_2
Applianceman2010 wrote:Are you SURE one of the brushes havn’t snapped or jammed in the holders?
Hi,Thanks for that, I’ll check it.
JM2
June 10, 2011 at 8:47 pm #353343JM_2
Here is the link to the manual which shows the Dials and buttons ;
Link to Manuals :http://www.bosch-home.co.uk/download-pr … nuals.html
ThanksJM2
June 10, 2011 at 9:50 pm #353344JM_2
Hi,I have checked the motor brushes. They are intact and OK.
JM2
June 10, 2011 at 10:03 pm #353345JM_2
Applianceman2010 wrote:Heater?
Hi Applianceman2010,Thanks for the reply.
Are you saying that the Heating Element has gone ?
If they have gone, would all the lights go off.
How can I be sure ?
Also if the heating element has gone, would I normally be able to use the spin or pump programme. Or cold wash ?
None of the lights coming on !
ThanksJM2
June 11, 2011 at 5:25 am #353346Applianceman2010
I’m just thinking mabe the “click” was the PCB bringing on the heater and it blew, taking the PCB with it …. 😐 just a possibility.
June 11, 2011 at 10:10 am #353347JM_2
Applianceman2010 wrote:I’m just thinking mabe the “click” was the PCB bringing on the heater and it blew, taking the PCB with it …. 😐 just a possibility.
Hi,That doesn’t sound too good. Not very good design if the PCB goes just because the heater element has gone.
So it’s not worth changing the heater element ?
Thanks for all the assistance.
JM2
June 11, 2011 at 11:18 am #353348Applianceman2010
It’s only a theory but defo. Worth checking the element.The “click” could of come from any thing really ,motor relay ,door switch but from what you have described it doesn’t sound good 😕
