Re: Siemens Washing Machine WXL 120GB/01 Stopped : No Lights
Ok so first of all you need to get at the heater which I believe is at the print on these. You can either tip the machine on its back or take the front off its up to you. Then you need a multimeter to check if you have continuity through the heater or weather it us open circuit. But to be honest if the machine is completely dead I would be trying to find out the cause of this first of all 😉 check the PCB isn’t blown or damaged in any way. Hth DJ
