Siemens washmachine pump cover
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Siemens washmachine pump cover
  • #66523
    robinahy
    I have a siemens E14-44 e. nr. WM14E442/13 FD8909600174
    I’m getting F18 error code. I think that has something to do with the pump cover. i used the black drain hose and emptied everything but I can’t open the pump cover. It will only turn a small ways to the left but not enough to be able to remove it.
    Any ideas?
    #364425
    Applianceman2010
    Re: Siemens washmachine pump cover
    Sounds like something is jammed inside the pump. Turn machine onto its back , try turning it back and forth. If that doesn’t work pump off. And remove what ever is jammed inside. hth 😀
