Hi all I have a Siemens washer dryer, washer side all working fine. Dryer however when selecting auto dry runs for around 7 mins then just stops. If you then try to select timed dry will run without fan.
The heater was low insulation so has been replaced no other earth faults found .
Since replaced dryer pcb and ntc.
Did run on timed dry to start with .then tried auto dry again and reverted back to only running for around 7 mins with a full freshly spun load (2.5 kg).
Any ideas I’m suspecting main pcb .
Regards
Darren
Sent from my iPad using Tapatalk
