Well lads new to this site.I was out with the above washer dryer today with fault e01.Fixed fault which was flood protection but cant clear the memory.any help would be great!![u][/
It’ll be a WDI1640GB/01,02 or 03 I would imagine. Rubbish machine to bear the Siemens badge (some Italian made tosh I think). You will need to turn off the water supply, remove the aquastop coupling to vent it, then reconnect, turn the water on, turn the power back on and fire the beast up!
If that doesn’t work….replace the Aquastop Hose Assembly.
Thanks Martin and Jim
Left it plugged out over night customer says it’s all sorted now thanks lads!!
Yea doesn’t seem to be a great machine bad design with the U shaped dispenser hose..too easy for cheap detergent to clog it up..
‘U’ shaped dispenser hoses are common on washer dryers, it stays full of water to prevent the air from being blown out of the dispenser hose during the drying cycle. 😉
