Siemens WI14S440GB/27
  • #61733
    Alanj
    Hi Guys,
    any Bosch/Siemens engineers out there got procedure to reset fault code on above integrated machine. Error F43 Motor fault has occurred in display. Machine only a week installed. 😥
    Alan
    #347410
    bosch-engineer
    Re: Siemens WI14S440GB/27
    Turn the program knob from the “off” to the 6 o’clock position. Press & hold the spin reduce button whilst turning the program knob one position clockwise. Release the spin reduce button, you are now in the test program. Turn the program knob to the “off” position, this has now reset the module. Although F43 suggests a motor fault, it will also be displayed if the belt has come off as the module detects no load on the motor.
    #347411
    Alanj
    Thanks for the reply Bosch-engineer. 🙂
    Alan
