Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Siemens WKS1420GB/01 bearings
- This topic has 13 replies, 3 voices, and was last updated 13 years ago by
iadom.
March 14, 2013 at 2:26 pm #74571
ModeratorIs there a complete bearing kit and seals for this old tub?
March 14, 2013 at 3:05 pm #392048Martin
ParticipantRe: Siemens WKS1420GB/01 bearings
Would that be a WK61420GB/01 washer dryer Jim? If so the Qualtex BKT72 should be the correct one.
March 14, 2013 at 3:18 pm #392049iadom
ModeratorRe: Siemens WKS1420GB/01 bearings
Could be Martin, the numbers have rubbed off a little. 😆
Although apart from the usual label on the top, inside of the door there is a larger label just above the door on the cabinet front that just has WKS142 in large letters/numbers and nothing else????
Ta for part number.
March 21, 2013 at 1:39 pm #392050iadom
Bigger,got it all stripped down only to find that BKT72 is the wrong kit. Both bearings and seal are bigger in this machine than BKT72. Any idea of correct kit?
March 21, 2013 at 2:52 pm #392051Martin
iadom wrote:Any idea of correct kit?
Gen= 086309 Qualtex= BKT76
March 21, 2013 at 2:53 pm #392052iadom
This is the old bearing and seal next to the ones from a BKT72.
Could it be a BKT61 that I need, BKT76 doesn’t look big enough?
going to try and clean up the bearing to see if I can find its size.
March 21, 2013 at 3:00 pm #392053iadom
Large bearing looks like it is a 6306 C3.
Jim.March 21, 2013 at 3:42 pm #392054Martin
Sorry Jim but I’m out of ideas on this one. Never come across a WKS before either. The only BSH bearing kits I carry on the van are BKT’s 72, 76 and 77. :con:
March 21, 2013 at 3:57 pm #392055iadom
Well Masterpart have their version of BKT61 in stock but only have the gen £58.00+ 086309 :eeek: , not their version of BKT76. 😥
Still get all my Qualtex stuff from DS Supplies or Howards Electrical as they are now but they take a little longer to deliver.
Makes it worse when its a built in machine, and belongs to a friend of over 35 years. 😥
March 21, 2013 at 4:01 pm #392056Martin
BKT61 is for AEG though isn’t it?
March 21, 2013 at 4:41 pm #392057iadom
Yes, but it is also listed a Bosch on page 72 of my ‘old’ Qualtex hard copy catalogue. 🙂
March 21, 2013 at 5:27 pm #392058timdowning
Connect show kit brg9115 dosen’t say sizes on there though.
It does cross ref to BKT76. But who knows if the cross reference is correct.March 21, 2013 at 6:17 pm #392059iadom
Ordered both just in case, can’t risk getting the wrong ones twice. 😥
March 25, 2013 at 7:51 pm #392060iadom
BKT76 it was. 8)
