Hello forum,
I have a Siemens washing machine WM12P160GB/03 which wont drain.
I have cleaned out the filter and drain pipe several times, both are clear, but it still reports the same error.
When switched to Empty, the machine makes a loud humming noise, but doesn’t start the drain sequence (drain sequence is normally louder with a definite sound of pumping water).
The fault is intermittent, because after filter cleaning where I check and turn the impeller manually it seems to work again, but then fails on the next full run cycle.
Any ideas?
A problem with the pump? brushes perhaps?
I previously replaced brushes on the drum motor about 12 months ago.
Ray
PS, I just discovered that I can trick it into draining by switching it to ‘refresh’ program and letting it turn over a few times, then back to empty and it starts to drain ok…
I’m puzzeled now?
