Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Siemens WM12P360GB Spin Problem
- This topic has 15 replies, 4 voices, and was last updated 8 years ago by
nemonon123.
March 13, 2018 at 10:51 pm #93529
nemonon123
ParticipantEvening all,
I have a Siemens WM (model no as above) which has become a labour of love after replacing 2 x sets of drum bearings over the last couple of years, and I am therefore loath to junk it and spend £500 replacing it.
Relevant (?) background as follows: 7 weeks ago fitted set of Bosch bearings, seal and split drum seal after previously replaced cheapo Chinese set gave way after exactly a year. At the same time I replaced 1 of the 3 shock absorbers. Carbon brushes were replaced in Jan 16 during first bearing replacement completed after help from this site.
Problem now is that 9/10 times it won’t run a full spin cycle. Motor starts to run up but gives up at about 50 rpm once drum begins to wobble. Machine is draining ok, motor sounds ok, test wash cycle on empty has spun normally up to 1200rpm and a couple of washes has actually spun normally during my diagnosis so, unfortunately whatever it is, is showing up as an intermittent fault.
I’m obviously thinking it might be an asymmetric load sensor or that sensors actually picking up load imbalance effect due to my replacing only 1 of the 3 shock absorbers last Jan.
Having offered all this, the wiife has mentioned that post-wash clothes have been wetter than normal over the last few months, so maybe it’s a problem that is progressively getting worse and the above is all a coincidence?
I would appreciate any advice that can let me save this machine from the scrap heap.
CheersMarch 19, 2018 at 5:05 pm #454680nemonon123
ParticipantRe: Siemens WM12P360GB Spin Problem
Anyone know where the imbalance sensor is on this model? Definitely related to imbalance as it keeps just getting up to speed and then quits.
I’ll replace the springs and 2 remaining original dampers at least.
Any help appreciated as the missus is getting a little impatient with my make do and mend ways!March 19, 2018 at 5:26 pm #454681electrofix
ModeratorRe: Siemens WM12P360GB Spin Problem
if the springs are not broken then they wont need replacing
does it spin with no load in ?
March 19, 2018 at 6:54 pm #454682nemonon123
Yes, it spins ok without any clothes.
I’m beginning to think it may be the more obvious drain problem. In a light mixed programme just now it spun up normally but then failed to spin at the end of the programme. So I drained the drum from the pipe at the front and the coin trap next to the pump and removed about 800cc of water which I figure may be enough to prevent the machine from attempted by to spin?
I have recently moved home and am wondering whether, after moving it into the new position, a slight kink in the drain hose (looks fine to me) might generate enough back-pressure to prevent full drain?March 19, 2018 at 7:42 pm #454683electrofix
how does the hose connect to the drain ?
March 19, 2018 at 8:32 pm #454684nemonon123
Hook-over pipe
March 19, 2018 at 8:58 pm #454685electrofix
make sure it only goes down the pipe for about 8 inches as most people tend to push it to the bottom and that can cause problems
dave
March 19, 2018 at 9:04 pm #454686nemonon123
Back to square one: no spin after having manually drained at end of whites cycle this evening.
Any idea how these machines detect an imbalance during the load distribution process?March 19, 2018 at 9:25 pm #454687electrofix
most of the time its detected by motor load. if its out of balance the motor will need to work harder to pull the washing to the top of the drum and as it comes over the top it gets easier to get it to the bottom
just like driving a car up and over a hill
it looks like this unit has a brush motor. Have you checked the brushes ?
March 19, 2018 at 9:34 pm #454688kaibart
I’m not sure if this has a 3d sensor fitted on the top back end of machine with the lid off it’s in the back top right hand corner make sure you unplug 1st though
March 19, 2018 at 9:36 pm #454689kaibart
It looks like this
March 19, 2018 at 9:46 pm #454690electrofix
there are 21 models of this machine
looked up WM12P360GB/03
and this one has this sensorhave you had these go faulty Kaibart ?
March 20, 2018 at 5:00 pm #454691kaibart
No I’ve had them not fitted right but they are to do with the obb
March 20, 2018 at 11:46 pm #454692nemonon123
Thanks gents, I appreciate the help.
Replacement carbon brushes were done 14 months ago when I did the first set of bearings.
Top’s off and springs look fine but there is s pronounced wobble as the drum starts to spin up. I’ve no idea whether that is as should be or not. Springs look fine and can access the imbalance sensor mentioned. For further diagnosis, if I was to unplug that sensor would it remove the protection and spin, or just default to a safe ‘no spin’?
Any way of testing the output voltage if that sensor to see whether it’s working properly or not?
I’ll try the simple and cheap stuff like brushes first on Friday and then have a go at replacing the imbalance sensor (£55!). Will let you know how this progresses.April 2, 2018 at 11:40 am #454693nemonon
Update to this problem which is still not resolved:
Motor brushes are fine. Half-worn already (14m old) but still good enough.
Machine seems very sensitive to a heavy load and will spin normally when a light, varied mix of washing is in there (ie easy for the drum to distribute evenly relatively quickly?). Heavy items like towels and bath mats are troublesome and will often take 3-4 attempts at spinning to get it to work properly. This has me thinking that it is
a. an over-sensitive balance sensor or
b. a real imbalance issue that the sensor is picking up properly due to asymmetric performance of the shock absorbers, (I only changed 1 of the 3 a couple of months ago having damaged the plastic mounting lug upon drum removal). Are these shock absorber mounts that critical in maintaining an even drum motion and should they always be replaced in sets to ensure even performance?
Appreciate any assistance offered to help – I’m getting close to junking this one. -
