Siemens WM14E162GB/15
  • #79010
    rocker
    there is a slight leak from the left hand sise of the soap dispenser, have checked the fill tube to tub, cleaned the inlet holes top tray, lowered the water pressure, checked machine is level. still no joy, thinking of changing the complete soap dispenser. as anyone else come accross this fault . thanks john
    #407587
    Re: Siemens WM14E162GB/15
    Have you cleaned the air vent hose between the dispenser and tub?
    #407588
    rocker
    yes vent hose is clear
    #407589
    rocker wrote: thinking of changing the complete soap dispenser.
    You will only need to replace the dispenser top (00641845). Easy fix and only costs 13 quid! 😀
    #407590
    rocker
    Cheers Martin. john
