siemens wm14p160gb03
  • #89820
    mike1
    hi
    I have got to order and fit a p.c.b. 707990 to this machine and was wondering does it have to be programmed, and if it does can I do it? i.e. does it come with instructions.
    regards
    mike
    #442657
    kaibart
    Re: siemens wm14p160gb03
    Yes it will need programming but all the Bosch modules I’ve ordered come with instructions on how to programme. Kai
    #442658
    Yes Mike as Kai says they do come with instructions. Very complex, specific instructions they are too and not a job to do last thing on a Friday that’s for sure.
    I hope for your sake the machine really needs the module?
    And I do have the coding instructions if you get stuck. :tup:
    #442659
    mike1
    thanks for your replies, I will now order the module and let you know how it goes, the reason I have gone for the module is because the machine wont heat up and there is no power to the heater.
    mike
