Have a Siemens washing machine in the wprkshop at the moment. Wm14p360gb/03 and f18 is coming up near the end when it should be going into spin?
Im led to believe f18 is a draining error. Check pump and filter and waste pipe all clear. However did find the pipe going from drum to the electronic pressure clogged up so cleared that. But now when i select the spin function it will constantly drain but drum won’t even attempt to rotate. It will rotate ok however when i select a wash program but again it stops when it should be going into spin and f18 comes back on.
Any ideas? Pressure switch or motor?
