well according to the Siemans E23 is flooded base as expected but as you say this machine is not fitted with it.
the ciruit to the flood switch can either be open circuit thats closed when flooded or closed circuit that open when flooded
so
the only thing i can thing of is all machines have this facility and to stop it coming up on machines without they may short out the connector with a wire link
or if the opposite is true the connector has been contaminated with a leak shorting the plug to cause the error
