Probably a long shot, but this machine doesn’t let the softener through.
Its got 2 neons on the soap box handle to let you know when its running out of fluid – it has tanks in the drawer to last for several washes- bleeding stupid idea if you ask me , surely the stuff would go off?
The lamps should stay lit & only flash when running low , but they only light when you shut the drawer momentarily
Took the lid off , no obvious faults,ie loose cables etc.( pcb at the back that possibly controls this procedure, not sure really.)
Probably tell them to go back to Siemens, unless anyone here can help.
HELP!!!!
Clive.
