the lights come on the on off light flashes but when you touch the button it doesnt start,
the door doesnt lock i am thinking the door lock is faulty its not a clicking type just a normal looking interlock,
anyone had similair problems or other thoughts?
Hs the customer got the signals volume turned down/off ? – Normally if the door lock fails and the appliance won’t start , it will double-beep you , giving an indication state of door open when its actually closed .
Martin’s prob correct with his interlock advice :waving:
hi,
thanks for the reply checked the connector going to the interlock,
dont know about the volume but i am going to order a door lock and give it a try!
thanks again.
