Siemens WM16S794GB/09 child lock/F27
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Siemens WM16S794GB/09 child lock/F27
Viewing 1 post (of 1 total)
  • #76915
    Have a Siemens WM16S794GB/09 washer stuck in child lock and the display alternates between ” have to select easy care” and “last stored fault F27. Any attempt to reset is greeted by a beep and “child lock activated” message. Have checked motor brushes and heater etc, no water in tub, pressure tube clear, but uses transducer type pressure switch so difficult to tell if ok or not, but if this is unplugged, the drain pump comes on and runs continuously.
    no obvious blows on pcb, anyone had before?
    Thanks for reading.
