Siemens WM21050/GB12
  • #19157
    Ken.C
    Problem as follows:Pre-wash: fills – tumbles/spins – drains (all ok).
    Main Wash: fills- no tumble/spin – drains. Rinses: 1st fills-tumbles-drains ok. 2nd fills only. Spin Cycle: No action.
    Is this a programmer/timer fault and if so is it worth replacing or should I be looking for a new machine?
    #181936
    gegsy
    Re: Siemens WM21050/GB12
    I would check the pcb module for dry joints as a starter.
    Un plugged before attempting this :plug:
    Ken.C
    Thanks for the advice. I removed the pcb module which shows signs of a flashover at junction of large ceramic resistor and diode. No obvious damage to components/pcb (apart from soot) or dry joints. Cleaned edge connector and replaced. Machine does not spin/tumble at all now so is this the problem?
    #181938
    gegsy
    A look at the brushes couldn’t hurt. Failing that, may I suggest you use the link below for an engineer to confirm problem.
