Re: Siemens WM2300 pressure switch wires
Baron
ill have a go to relay to you Pressure switch number first
timer blocks x1black x2 red x3green x4yellow
door lock n1 nuetral c2 live out
24 timer black block x1 terminal 9
21 timer black block x1 terminal 3 plus door lock n1
12 timer red block x2 terminal 9 link to 22 on p/switch
22 link to 12 on p/switch plus wire to cold water valve
11 wire to heater
4 wire to drain pump plus timer red block x2 terminal 4
14 timer green block x3 terminal 12 plus wire to door lock switch c2
hope this is not too bad
alro
