siemens wm5100gb/14
  • #40749
    randomrob
    hi
    i have a siemens w/machine that is doing some strange things..
    when put onto any wash cycle the timer clicks half way around the main wash display before working, it also does not finish the cycle and can get stuck on any part of the cycle. When the timer is clicking around at the begininning of the cycle the pump will come on for a second then continue to click, then the water valve will come on for a second then the pump then the water valve before finally starting to fill up with water. Not sure if this will make any sense to anyone but any advice will be gratefully received…..the valves have continuity as does the element and the pressure pot has been checked and is clear, it also pumps the water away and will go into the spin ok if put on a spin cycle.
    #267411
    randomrob
    Re: siemens wm5100gb/14
    hi
    just an update on the problem..this was fixed by replacing the timer
