Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Siemens WM71631/01 no drum action
- This topic has 12 replies, 3 voices, and was last updated 19 years, 5 months ago by
admin.
November 11, 2006 at 4:03 pm #22468
KeymasterWM71631/01 FD7309 Seriel00653 has no drum action and neither door cannot open from button. If I select for washing indicate the door locked and start to fill water and further nothing… No error…
If select spining program also starts to pump out and also no drum action and neither error… at the end of program cannot open door from button.
Advice?November 11, 2006 at 4:36 pm #195087gegsy
ParticipantRe: Siemens IQ716 no drum action
Hi Baron
The door lock may think it still has a certain amount of water left in the drum. You could drain appliance down at filter and then try again. The same goes for the spin cycle also, ie certain level of water detected- No spin.
PS – This has a manual door unlock behind filter door just like the Miele 😉Greg
November 11, 2006 at 4:43 pm #195088admin
KeymasterI know but it is no water inside now… It has one “water sensor” on one tube and also overflow sensor. I have tried with that sensor dismantled from his case, to get in spin cycle but nothing…
November 11, 2006 at 5:03 pm #195089gegsy
Ok assuming brushes and motor check out ok, then I would be looking personally towards interlock or module fault, as you have checked the pressure system already 😉
November 11, 2006 at 5:07 pm #195090gegsy
Baron……….Check your email 😉
November 11, 2006 at 7:27 pm #195091admin
KeymasterRe: Siemens WM71631/01 no drum action
Thanks Greg, :tup:
Excuse for delay but I was gone from home.
I will check all on Monday.P.S. You’ve assumed right that I’ve checked pressure system and door lock. 8)
November 11, 2006 at 7:30 pm #195092gegsy
ParticipantRe: Siemens WM71631/01 no drum action
baron wrote:P.S. You’ve assumed right that I’ve checked pressure system and door lock. 8)
Of course your an engineer 😆
November 11, 2006 at 7:45 pm #195093admin
Greg :beer: :beer: :beer: :pirate:
November 11, 2006 at 8:31 pm #195094gegsy
Now you talkin, and I reckon you owe me a few pints 😆
November 11, 2006 at 9:01 pm #195095timdowning
Had low insulation on heaters hold door locks on, may be worth eliminating first before ordering modules!!!
November 14, 2006 at 5:33 pm #195096admin
Greg, I have tested today.
After entering in test program, first it shows F10. I have set it for motor test and it worked without any error. It is already in third probe and goes OK. 8)I didn’t find anything wrong before getting into test.
Please, what means F10 (I don’t have error list for this machine). :bounce:Thanks 8)
November 14, 2006 at 5:41 pm #195097gegsy
Hi Baron
F10 is no communication between power module and motor control PCB.Either faulty PCB/s or loom connection fault.
November 14, 2006 at 6:13 pm #195098admin
KeymasterNICEEEE….
I can not explain how it’s possible to repair or remove one problem without doing anything, only getting into test (without touching any cable or module).Thanks’ again GREG…
