Home › Forums › General Trade Forum › Siemens wt36v398
- This topic has 11 replies, 3 voices, and was last updated 11 years, 7 months ago by
timdowning.
September 10, 2014 at 7:52 pm #82190
timdowning
ParticipantEvening,
I’m trying to download the user manual for this dryer but all I can find on Siemens site is the installation guide and something about a woolens basket! Mainly the page on how the dryer ends, as in what is in the display and what lights are on if any.
Help!Ta.
September 10, 2014 at 8:33 pm #419081Martin
ParticipantRe: Siemens wt36v398
Bit of a siemens download cock-up that’s for sure 🙁
Download the WT36V394GB instead as they are pretty much identical. 😉
September 11, 2014 at 7:03 am #419082timdowning
Cheers Martin.
After varying lengths of time this dryer stops with the filter / hose light on and three bars in the display. I had it running for 90 minutes yesterday and all was well until I left. They say it normally stops after 10 or 15 minutes. The machine is spotless and the vent is perfect. Any thoughts?
Tim.
September 11, 2014 at 8:10 am #419083Martin
I can only imagine it is a fault with the exhaust NTC.
September 11, 2014 at 1:23 pm #419084timdowning
Where is it located on this model? Do you have any idea how you get to it? Thanks.
September 11, 2014 at 2:35 pm #419085Martin
timdowning wrote:Where is it located on this model? Do you have any idea how you get to it? Thanks.
It’s a very basic dryer this one
and the NTC is located on the heater box.September 11, 2014 at 4:25 pm #419086timdowning
I thought you were meaning the ntc that is at the front, normally embedded in the filter area.
September 11, 2014 at 5:13 pm #419087Martin
timdowning wrote:I thought you were meaning the ntc that is at the front, normally embedded in the filter area.
I looked at the parts breakdown and it appears not to have an exhaust NTC. 🙁
September 11, 2014 at 7:40 pm #419088stratfordgirl
The heater unit appears to incorporate an NTC and thermostat on the top plate (both separately replaceable) and a device (wired to the heater, mounted on a separate bracket and not individually replaceable).
September 11, 2014 at 8:27 pm #419089timdowning
Martin it does have the front ntc, item 0216. Is this the one you were referring to originally?
September 11, 2014 at 9:12 pm #419090Martin
timdowning wrote:Martin it does have the front ntc, item 0216. Is this the one you were referring to originally?
Yeah that’s the one, well spotted 😀
September 12, 2014 at 5:54 pm #419091stratfordgirl
Ah, yes, but apparently dropped from the GB/11 version, unless the diagram is wrong.
