Siemens WT46E389gb/17 Dryer
  • #81971
    ray.t
    I have had a call today to look at one of the above dryers.
    Customer is saying the timer is jumping from 2hr 12mins down to 30 mins then back up to an hour and so on, eventually stopping but showing the original time on the display.
    I don’t know if this is likely to be a sensor fault or a pcb fault.
    Cheers Ray
    #418310
    Re: Siemens WT46E389gb/17 Dryer
    You’ve gotta hope it’s just the front NTC because the PCB is the wrong side of 250 quid….!?!!!
    #418311
    ray.t
    Ouch, that’s a bit pricey then. Front NTC is only a few quid so I think I will try my luck with that first.
    Cheers,
    Ray
    #418312
    ray.t
    Just to update this, it was the front NTC.
    Cheers,
    Ray
