weve had this heat pump tumble dryer just over 6 years now. I seem to remember the fan would occasionally come on to presumably cool the fridge unit down in the bottom of the appliance. for some time now I haven’t heard it.
is it thermostatically controlled? the only change is weve moved and it sits in a cooler room.
I doubt many, if anyone has any experience with those as they are low volume and most are likely to still be under a Siemens warranty.
There is a fan on the main drive motor and a small, looks to be a low voltage one, at the front. I presume the front one does as you think so, if the room was cooler then it’s all too likely it will need to draw in cool air less.
I removed the fan as it was quite easy to do, though broke one plastic retainer fitting the new one. I tested the fan and it was open circuit so replaced it with this one:
seems identical other than the last three numbers which are an oem part. I did have to retap an earth on another hole on the fan so it matched the original. but appart from that all good touch wood.
