Siemens Extraklasse XL120
E- Nr. WXL120 GB/01
FD 8108 700104
I’d appreciate some help.
Good news is that water goes in. Seems to heat up. Machine turns.
Unfortunately, The water will not drain.
On a short programme the water goes in. The machine turns for few minutes. Reaches the red light : Rinsing. The minute indicator on it goes blank. Water remains and is not drained.
When I try the following programmes
1. Rinsing
2. Spin
3. Pump
The machine makes a buzzing noise and nothing happens.
I have cleaned out the filter at the bottom of the machine on the right hand side.
After letting all the water out manually and through the filter , I tried the 3 programmes again . :
Rinsing :
Spin :
Pump
Still making just the ” buzz ” noise.
Checked the Water outlet pipe seems clear .
Thanks 🙂
