Never thought of that Martin.
If not then the chances of it being the pcb??? or could the pressure switch be at fault? although it did click just the once.
Rob
robbra wrote:If not then the chances of it being the pcb??? or could the pressure switch be at fault?
Well, can’t rule out PCB of course but would’nt suspect the Pressure Switch TBH. Also of course it does have a ‘anti-flood device’ in the floor pan, so maybe that needs checking out? 😉
