Siemens Wxl166agb /09
  • #44581
    ray.t
    Hi, Been to look at one of these today that is totally dead.
    Does anyone know if the interlock goes on this machine will it cause this fault.
    I took the main board off from behind the front panel and there is no sign of any damage on it, but it is totally dead no lights no display nothing.
    Cheers Ray
    #281487
    Specialist01269
    Re: Siemens Wxl166agb /09
    Hi Ray: Don’t think i’m trying to teach my granny to suck eggs but i’d check the filter first then the interlock you should be able to bypass the interlock to prove the point.
    Andy.
    #281488
    Display should light up on power up regardless of door being locked or not.
    ray.t
    Hi Thanks for the info. Sorry I should have put that I checked the filter and it has power at the board. One other thing the customer did mention was that for a while now the machine had been jumping around a bit.
    Cheers Ray
    #281490
    Specialist01269
    Sorry Ray: Not thinking straight at the minute, 🙁 hope you get it sorted.
    All the best: Andy 🙂
