Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Siemens WXLM148AGB/19 auto – no start/lights
- This topic has 4 replies, 2 voices, and was last updated 14 years, 11 months ago by
MickGeorge.
May 3, 2011 at 1:24 pm #62555
MickGeorge
ParticipantHi folks
Been to this today and suspect module but would just like a bit of reassurance pls 🙂
Customer says control been intermitant at selecting program and not coming on but was ok as long as m/c not switched off at dial – now not coming on at all.
Supply into m/c and up to main board – no indicator lights on at all and nothing when you try and select a program. checked motor and door lock but all seems ok
Suspect module/selector switch as they been having previous problems with selector but would just like some comfermation I havn’t missed something stupid.
Thanks – all comments appreciated.
Mick
May 3, 2011 at 3:59 pm #350453Martin
ParticipantRe: Siemens WXLM148AGB/19 auto – no start/lights
MickGeorge wrote:checked motor and door lock but all seems ok
How can you check the door lock if the machine is dead? 😕
MickGeorge wrote:Suspect module/selector switch as they been having previous problems with selector
Hmm?….could be?….what were the “previous problems” anyway?
May 3, 2011 at 4:40 pm #350454MickGeorge
Hi Martin
Did a quick check on door lock heater to make sure it wasn’t o/circuit but grasping at straws really as would have expected some lights up somewhere but there are no lights showing.
Did explain previous probs were intermitant selecter opperation – sometimes it would select, lights came on and worked ok through wash – other times would not come on/ no lights showing, and then once they had fiddled with the selector a bit and got the lights to come up it worked fine. Just sounds like a dodgy selector to me altho it feels ok??
Thought someone might have had a similar prob with a Bosh or Siemans as they the same more or less and suspect they use the same boards.
Thanks for the reply
Mick
May 4, 2011 at 8:08 am #350455Martin
MickGeorge wrote:other times would not come on/ no lights showing, and then once they had fiddled with the selector a bit and got the lights to come up it worked fine. Just sounds like a dodgy selector to me altho it feels ok??
Sure sounds like it to me too. Costly blighters though aren’t they? 🙁
You’ll just have to go with it I guess….fingers crossed! 🙂
May 5, 2011 at 8:45 am #350456MickGeorge
Thanks for the reply Martin
Suspect module as power in nothing out – not even lights but I just know these days nothing as straight forward as it seems and just wondered if I had missed anything.
Would have expected if module/selector ok I would have got a light or lights up somewhere even if door lock or something else faulty – but there again who knows in this day and age of improving technoligy :rolls:
Thanks again
Mick
