Siemens WXLS122GB – Drum does not turn at all
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Siemens WXLS122GB – Drum does not turn at all
  • #43270
    di7ip
    Hiya guys,
    Back again (in such a short space of time). This time it’s the Siemens Washing machine, model :WXLS122GB, Approx 5 years old.
    Following are the symptoms:
    In any programme, it will take on water and pump off at the due time but the drum fails to rotate, spin etc.
    Quick look:
    No apparent error codes.
    Belt is intact and still on (unfortunately)
    Drum rotates freely, although possibly more easily than before, but I can’t be sure. (Does this motor have brushes? or is it an induction type?)
    Any help/advice appreciated guys
    Thank you
    #276686
    Re: Siemens WXLS122GB – Drum does not turn at all
    Yup, brush motor – article HERE will help. Brushes to fit your machine are HERE.
    Power off first, please.
    di7ip
    Hi Penguin45,
    Spot on as usual. Replaced the brushes and everything back to normal. I would have thought there would be an error code for such faults but hey – who needs error codes with you guys around. Thanks once again for your (quick) help
