siemens xl534
  • #48821
    spanishwhite
    original fault was the machine would not empty. Small blockage in outlet pipe, now however whatever cycle is selected the pump comes on straight away and the machine will not fill etc. Is it likely the pressure level switch is faulty?. Any help please
    #297836
    nomadPaul
    I would suggest checking the base pan for water. You may have an anti-flood device in the base being operated by some water laying in the baseplate
