How can I adjust the water level on a Siemens XLM washing machine?
I want to increase the wash and decreas the rinse water levels in my Siemens XLM 1200 washing machine. I have adjusted other machines before which normally have a simple variable resistor. The XLM has a module with several adjusting screws and they seem to interract with each other. Advice will need to clearly identify the adjusters.
Seems strange. Surely if the level module fails and is replaced the technician will have to set the water levels. Siemens technicians must know how to do this.
As washman says, the pressure switch is preset. That goes for 99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of all pressure switches on all machines on the market.
