SiemensWT46E387GB/03
  • #54967
    reaper
    Got 2 of these both with no heat.One has a faulty heater but both have exhaust thermostats mounted at the front (2 brown wires) that are open circuit.Im presuming that these are the problem as on most driers – just seems unusual to have the same fault on two rare(in this neck of the woods) machines.Can only think blocked condensers would cause this problem but both are as clean as whistle.
    #321546
    Re: SiemensWT46E387GB/03
    NTC sensors – set meter to kOhms and check the readings.
