Simpson Eziset 550 wont start 3 flashing lights
Home Forums Public Support Forums International Forums Australasian Appliance Forum Simpson Eziset 550 wont start 3 flashing lights
  • #44149
    Cylon
    Simpson eziset 550 washing machine wont start, I press power on then the start button and beeping alarm starts with the three water temp lights flashing, I have replaced the cpu with a new exchange unit, it programs ok.
    On spin It just sits and waits. checked for all the normal faults. Any ideas anyone
    #279944
    Re: Simpson Eziset 550 wont start 3 flashing lights
    I can’t claim to know the product, but design convention on most washers will prevent the machine from filling if the pump is out of circuit.
    Cylon
    Found cause of lights, needs lid on (magnetic switch)
    Really dumbing down today
    However this did not fix it.
    Pump runs ok on its own, checked every valve and switch and motor on it now.
    result is Zilch, can only suspect I got issued a dud exchange cpu
    #279946
    bigsmokepiker
    Give me The Full Model
    At top Back of Washer
    #279947
    Cylon
    mod 36s550 s/n 42070153
    #279948
    bigsmokepiker
    All 4 Wash Leds Flashing ?
    Means Out Balance
    Check OOB knock off lever & Microswitch for OOB (Microswitch is normally closed) As opposed to LID Switch
    Fairly rare that PCB Goes Bung
    #279949
    Cylon
    No oob problem. in fact no alarms of any kind.
    I Just fitted another cpu that I ordered. This one is definitley faulty, it wont accept any programming inputs at all, and has a bad AC plug socket contact on the board that cuts in and out, so I guess this goes back too
    Contact works fine on the original one
    Still leaves me in same dumbfounded mess, with the original cpu. Machine sitting waiting for input of some kind, In progress light is on but no progress to anything. Spin or wash. (pressure s/w activated)
    I have tested the wiring loom. test run the motors and and valves, all work ok independantly
    I have noticed that I am being supplied with differing model and version numbers than originally fitted.
    I am being assured by the parts supplier that Once reprogrammed they should should work. Maybe Not methinks
    #279950
    bigsmokepiker
    Yes these pcbs have tp be programmed in
    But You should Instruction Sheet
    Is It Model 36S550L
    Ie give me the full MODEL eg 36S550L*01
    #279951
    Cylon
    36S550L*00 sorry didnt think this was part of the model # its a good inch or so away from the rest of the number s/n is 42070153
    #279952
    Cylon
    UPDATE:
    Fitted another cpu, also got service manual,
    panel passed all selfdiagnostic inputs from the manual with flying colours.
    Still wont go, just same fault
    #279953
    Cylon
    This one finally got me beat. wrote it off as uneconmic to carry on. Time is money. No prizes for this one Mr Simpson
