Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Siwamat E-Nr WM61201GB/01 No drum action
- This topic has 10 replies, 3 voices, and was last updated 13 years, 5 months ago by
snowy1998.
November 13, 2012 at 7:17 pm #72506
snowy1998
ParticipantSiwamat E-Nr WM61201GB/01
All actions of all the programs work, dont get any error codes, the problem is the drum does not move at all.
Tried removing and re-seating power board and noticed a lot of black around the small coil component near the back.
Only other notable thing is when you are expecting the drum to turn, all you get is a click from one of the four orange relays about once every 5 sec or so.
Any pointers appreciated
thanks
November 13, 2012 at 7:28 pm #384703Martin
ParticipantRe: Siwamat E-Nr WM61201GB/01 No drum action
Replace the motor brushes.
November 13, 2012 at 8:00 pm #384704snowy1998
Easy Job? or is there a how to on here?
I have had a look where the motor is and all the parts I think I need to get to are facing towards the front of the machine 🙁
Advice on how to get at it would be appreciated… Take out the floor pan (riveted) remove the motor? or just get them out in situ?
thanks
November 14, 2012 at 8:13 am #384705Martin
snowy1998 wrote:Advice on how to get at it would be appreciated… Take out the floor pan (riveted) remove the motor? or just get them out in situ?
I get the destinct impression this is some kind of wind up. :rolls:
Why not just take the back panel off to access the motor, after all the motor is at the back of the machine. Come on, you’re winding me up …surely?
November 15, 2012 at 5:37 pm #384706snowy1998
Sorry, it was not my intention to wind you up.
This is what I can see when I lie face down on the floor, yes the ‘motor’ is accessible and I can feel the bushes, but they are on the other side of the motor right by the drum drain hose so access is not great, hence the (well I though reasonable) question as to the best way to tackle it or do I just go face down and fumble around in the dark so to speak.
November 15, 2012 at 6:03 pm #384707iadom
ModeratorRe: Siwamat E-Nr WM61201GB/01 No drum action
Just take the motor out, remove the two bolts, one bolt head you can see, the other is accessed from the side, behind the angled motor bracket.
If and when you do this you will understand my esteemed colleagues incredulity. 😉
No need to lie it down at all.
November 15, 2012 at 6:18 pm #384708snowy1998
Many thanks, I always take action on a considered and informed basis. I dont like to charge in and just start randomly undoing things, well not since….. ahem, that’s another story altogether 🙂
Will go, spanner in hand, report back later..
November 15, 2012 at 7:37 pm #384709snowy1998
OK, motor out, brushes out and stripped, and yep, they’re worn 😉
I guess now I just need the brush to fit in the carrier, only thing I am aware of is that these are FHD carbon, no idea what that means, anything I need to be aware of?
P.S.
One caveat – that motor is heavy… turned into an impromptu guillotine when it pinned my pinkie on the edge of the frame…. OUCH!
November 15, 2012 at 9:01 pm #384710iadom
I think you mean FHP, these are the ones you need. http://shop.ukwhitegoods.co.uk/12hp20-f … on-brushes
Sent from my iPad.
November 15, 2012 at 10:03 pm #384711snowy1998
thanks, the link is for right hand brushes, mine are left hand, I guess these would work instead?
http://shop.ukwhitegoods.co.uk/12ag03-f … ush-insert
Dimension are an exact (well within 0.01mm) match.
November 15, 2012 at 10:09 pm #384712iadom
Those should be fine.
Sent from my iPad using Tapatalk HD -
