Slight electric shock off whirlpool AWM 8163
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Slight electric shock off whirlpool AWM 8163
  • #21730
    potnoodle
    Hi ,
    Just took a load of washing out of machine when i touched the drum i had a small electric shock.
    Could something obvious be causing this or is best left in the hands of an engineer?
    needless to say im not using the machine untill its sorted.
    Many thanks
    #192309
    gegsy
    Re: Slight electric shock off whirlpool AWM 8163
    Where was your other hand? On the sink unit by any chance 😕
    potnoodle
    gegsy wrote:Hi
    Hi Greg,
    Well im not sure lol, My husband is thinking that it was from static but im not convinced, btw would that make it happen if i was holding on to the sink
    thanks 🙂
    #192311
    gegsy
    It sounds like going to be an earthing fault either of the appliance or the socket. If your hand was on the sink unit stainless, then you will need to check there is a good earth on that aswell.
    The best advice to be safe is to get the appliance checked out by a qualified engineer and the house electrics by a qualified electrician IMHO.
    Regards
    gegsy wrote:It sounds like going to be an earthing fault either of the appliance or the socket.
    I would agree with that statement as the likely problem. 🙂
    You may wish to read the advice given in the link below as well. 😉
    http://www.ukwhitegoods.co.uk/modules.p … age&pid=76
