Slight Ice Buildup In Fridge Part Of Beko CDA543 Normal?
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Slight Ice Buildup In Fridge Part Of Beko CDA543 Normal?
  • #69767
    wokeye
    I just got a used Beko CDA543F frost free refrigerator. It seems to work fine except I have noticed a slight ice buildup of fluffy ice on the inside of the rear free fridge wall in a perfect rectangle shape that I am guessing is exactly where the evaporator is behind it. It goes if I turn the thermostat down to 1, which apparently starts the defrost heater. But it re-appears when the thermostat is turned back up. After watching it after being on all night there are also frozen water droplets so I would guess that the defrost heater is working and these were droplets that were formed when the defrost heater melted the ice but re-froze when the defrost heater switched off. It is really not that thick a layer at all. I just wondered is this normal as I cannot seem to find much information on the internet. There is no frost in freezer at all. Thanks for any help.
    #375896
    Re: Slight Ice Buildup In Fridge Part Of Beko CDA543 Normal?
    Yes, sounds normal.
    It will only defrost as the fridge cycles.
    wokeye
    Thanks for the reply kwatt that is good to know.
