Home › Forums › Manufacturer/WP/Insurer Specific Forums › ISE Trade Support Forum › ISE Forum (Closed) › Slight problem
- This topic has 5 replies, 4 voices, and was last updated 19 years, 2 months ago by
iadom.
January 23, 2007 at 5:34 pm #24423
ModeratorCustomer Mr Mills, Riverbank Delph.
Not an established customer of mine, first ever visit was just before Christmas to BER a Hoover/Candy with outer drum leak.
After years of dealing with the public you get an inbuilt feeling for people. After only two vists I had Mr Mills marked down as a retired engineer/know it all/ moaner.I did give them an ISE leaflet but didn’t turn on my usual charm, in fact I extolled the virtues of Bosch machines. I referred him to Star Supplies and bless them, they sold him an ISE, I installed it on the 8th Jan.
Went out to it today to be met by him saying he wanted me to take the machine away 😥 .
I have a strong feeling that almost all the problems are OOB related, they had difficulty selecting a wash programme and said it was stuck on spin. Also complained of being on spin for 30 minutes and almost 3 hours on 40° synthetics wash ( turns out she had selected extra rinse)
The one complaint that did bother me was that he said that they heard the machine make an almighty bang and found it had moved out a foot from under the work top.
The first thing I did was to set the machine to spin. It went through the spin cycle in 23 minutes, the user manual lists the spin time as 13 minutes.
They admitted that when it took 30 minutes to spin they had only one large jumper and a few socks in it.
I then put the load that had ‘jumped’ back in. A mixed load of towels and other items, I would guess under 3 kg in weight. The machine appeared to balance and spin them perfectly.I have given him a copy of the reset procedure following an OOB condition but I wonder if Martin or anyone else can run a couple of tests for me.
1. How long is the full spin cycle?2. How long is the 40° synthectics cycle with extra rinse selected.
I would also like to know if we have had any uncontrolled OOB conditions that could cause the machine to jump violently?
January 23, 2007 at 8:29 pm #202016kwatt
KeymasterRe: Slight problem
iadom wrote:I would also like to know if we have had any uncontrolled OOB conditions that could cause the machine to jump violently?
Nope, not a one. 😕
January 24, 2007 at 11:40 pm #202017iadom
ModeratorRe: Slight problem
Anyone had the time to test the programme times I mentioned ?
January 25, 2007 at 12:37 am #202018Penguin45
ParticipantRe: Slight problem
Martin did some extensive testing when we found out that the manual was a cock-up. Might be worth a word.
January 25, 2007 at 8:58 am #202019Martin
iadom wrote:1. How long is the full spin cycle?
Sorry it took so long to reply but unless you test the ISE with a washload the times are very different when empty.
So, SPIN ONLY (with a normal 4kg load of towels) took 15 mins.
2.5kg of synthetics @ 40 degs with rinse plus took 2hrs 20mins!
Hope that helps?
January 25, 2007 at 9:51 am #202020iadom
Thanks Martin, obviously I couldn’t verify their claim of over 3 hours for that wash setting, but I definitely timed the spin without clothes at a fraction under 23 minutes. 😕
I will just have to keep my fingers crossed that it was an OOB induced glitch. 🙁Jim.
