Slimline Philco
  • #26024
    Model. Ecotronic WD2003SL PFFS93490284.
    Motor is shot. Anyone know of cost/availability?
    gegsy
    Re: Slimline Philco
    Hi Jim
    Connect show motor PHL116190214 – ยฃ77.31 + costs
    With a foot note
    Ref metz and siemens type motors. These motors are no longer available you must use the indesco motor. On all these older models you will need to replace the module and the interface. Please see your supervisor for the correct part listings that you will need.
    HTH
    Re: Slimline Philco
    Cheers Greg, now tell me how I am going to explain that to a man of arab extraction who only speaks French. ๐Ÿ˜€
    PS. Is there any way to tell without going back which motor it had, it was mounted inside a square metal case with an arm of the case seemingly fitted to one of the suspension bolts. ๐Ÿ˜ฏ
    #208488
    gegsy
    Re: Slimline Philco
    iadom wrote:PS. Is there any way to tell without going back which motor it had, it was mounted inside a square metal case with an arm of the case seemingly fitted to one of the suspension bolts. ๐Ÿ˜ฏ
    I would stake money on it being a Metz 8)
    Only sure way would be to remove casing and motor. Loosen bolt of suspension leg, that arm should be just cupped in there ๐Ÿ˜€
    PS- As for Arab explanation, vous sur votre propre lร -bas dans la merde ๐Ÿ˜†
    #208489
    Re: Slimline Philco
    I preferred my,” le moteur est mort”, the best I could manage only having done 18 months French lessons almost 45 years ago. ๐Ÿ˜€
    Re: Slimline Philco
    Yep the Metz motor was the square one. forget it, the kits were next to useless.
    #208491
    Re: Slimline Philco
    iadom wrote:Cheers Greg, now tell me how I am going to explain that to a man of arab extraction who only speaks French. ๐Ÿ˜€
    Rรฉfรฉrence Metz et type moteurs de Siemens. Ces moteurs sont plus disponibles vous doivent n’utiliser le moteur d’indesco. Sur tous ces modรจles plus anciens vous devrez remplacer le module et l’interface. Veuillez voir le votre surveillant pour les listes correctes de partie des lesquelles vous aurez besoin.
    #208492
    Re: Slimline Philco
    What he said… ๐Ÿ˜†
    gegsy
    Re: Slimline Philco
    iadom wrote:What he said… ๐Ÿ˜†
    Je ne vous connais pas le supporter d’une รฉquipe trichante de football ๐Ÿ˜‰ ๐Ÿ˜†
    Re: Slimline Philco
    Two more French words for you, both signify footballing cheats, Pires & Henry, ๐Ÿ˜›
    #208495
    gegsy
    Re: Slimline Philco
    :shutup: :look:
