Slip-in oven AEG Competence 3215V gone bang
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Slip-in oven AEG Competence 3215V gone bang
  • #24126
    Lala001
    Our oven has just blown a fuse big time ( while main oven heating up).
    Funny buzzy noise, burning smell and black smoke. Then flashes from consumer unit when trying it out again.
    It’s nearly 7 years old.
    Is it worth trying to fix it?
    #200787
    Re: Slip-in oven AEG Competence 3215V gone bang
    Decent enough machine, should be worth investigating.
    Fan oven element is a good bet, possibly fan oven motor or occasionally the mains terminal block can carbonise with spectacular results.
    Power off when investigating.
    Lala001
    Do you think the display will still work?
    I’m sure it’s needed for the ovens to work, something to do with
    the clock time showing.
    Is it possible to disable the oven(s) and just use the hob part?
    Sorry, so many questions!
